i need to design a small signal amplifier in a voltage divider biasing, can anyone help??? pls???
R rLet Jan 1, 1970 0 Mar 7, 2006 #1 i need to design a small signal amplifier in a voltage divider biasing, can anyone help??? pls???
D David Harmon Jan 1, 1970 0 Mar 7, 2006 #2 On 6 Mar 2006 17:00:43 -0800 in sci.electronics.basics, "rLet" i need to design a small signal amplifier in a voltage divider biasing, can anyone help??? pls??? Click to expand... Yes, many would like to help. * Show what you have done so far * Ask very specific questions about the part that isn't working.
M [email protected] Jan 1, 1970 0 Mar 7, 2006 #3 rLet said: i need to design a small signal amplifier in a voltage divider biasing, can anyone help??? pls??? Click to expand... Maybe this will help: http://www.bcae1.com/transres.htm Mahurshi Akilla
E electronics kidu Jan 1, 1970 0 Mar 7, 2006 #4 Try this out. Goto http://ourworld.compuserve.com/homepages/g_knott/elect225.htm You will find help for your problem.
C Charles Schuler Jan 1, 1970 0 Mar 8, 2006 #5 rLet said: i need to design a small signal amplifier in a voltage divider biasing, can anyone help??? pls??? Click to expand... http://www.montagar.com/~PATJ/electrowares.htm Down about four lines is a free program for common emitter design. I have no idea if it is of any value. You can try it and you can Google for others.
