B
Boner the Cat
can I get someone to help me trace out the ignition wiring on a Dodge Dakota
truck. I have the relevant diagram but cannot read it. I have a crazy
intermittent fault and I want to make a hotwire system or circuit.
I can email the proper schematic to anyone that can help.
I know it is the ignition, because when truck stops, it looses spark.
I know it heat related, because if I leave the hood open for half hour, it
will run.
It also starts to get a weak spark after about 15 minutes
I checked spark by pulling the coil wire and holding to the chassis.
I have all new distributor, rotor, coil, wiring etc.
I don't think it is the pickup because that would not give weak spark???
would it.
I think their is a junction in the wiring harness that has some moisture or
weak connection that opens when hot.
it is definitely spark and definitely heat related.
thks
bg
will run.
would it.
thks
bg
