Help with Varactor Diode
abuhafss
Aug 3, 2010
348
Aug 3, 2010
348
Here is a portion of a circuit in which I want to replace the variable capacitor with a varactor diode like MVAM108. I know a little basics about varactors. Please help how to incorporate MVAM108 in this circuit so that it can be tuned with control voltage.
p.'s. http://www.tsf-radio.org/forum/im/133895mvam109.pdfScreenshot 2014-08-11 18.28.07.png
Harald Kapp
13,722
13,722
Varactor diodes are explained here. See section "varactor circuits" for applications.
Your circuit may not be suitable for the application of a varactor diode: A varactor diode's capacitance is controlled by the DC bias across the diode. Your circuit has an inductor in parallel to the diode. This inductor is a short-circuit for DC (apart from a typically low wire resistance of the coil). Any DC source that wants to apply bias to the diode will therefore be short-circuited by the inductor.
You may try to put a capacitor in series with the inductor to de-couple it from the DC bias of the varactor.
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
Nov 28, 2011
8,393
Yeah, a simple option would be to break the connection from the bottom of the inductor to the 0V rail, put a capacitor (e.g. 0.1 µF) across the break, and apply the control voltage across that capacitor.
abuhafss
Aug 3, 2010
348
Aug 3, 2010
348
KrisBlueNZ
Nov 28, 2011
8,393
Nov 28, 2011
8,393
Not quite. Move the cathode of the varicap to the other end of the inductor, then it's right.
KrisBlueNZ
Nov 28, 2011
8,393
Nov 28, 2011
8,393
Now you have the resistor connected to the wrong place. Connect the resistor to the top of the 0.1 µF capacitor.
abuhafss
Aug 3, 2010
348
Aug 3, 2010
348
You mean the junction of the inductor and the 0.1μF cap?
In that case the varicap will be reverse biased thru the inductor?
Harald Kapp
13,722
13,722
Kris: For DC this should make no difference.
KrisBlueNZ
Nov 28, 2011
8,393
Nov 28, 2011
8,393
With a 100k series resistor, it won't make much difference, no. I didn't actually suggest using a series resistor. My suggestion was to apply the control voltage straight to the capacitor. This avoids any effect on the Q of the tuned circuit. With a 100k resistor, that effect would only be tiny, but there would be a small delay waiting for the capacitor to charge. My suggestion was intended to avoid both problems.
abuhafss
Aug 3, 2010
348
Aug 3, 2010
348
And how the varicap would replace the capacitor in this circuit?
And where the control voltage will be applied?
