Help! With troubleshooting SMPS for a Denon reciver. (Low output voltage)
Discussion in 'Troubleshooting and Repair' started by 23komma4, Mar 16, 2019.
  1. 23komma4
    23komma4
    Mar 16, 2019
    I'm trying to fix a power supply for a denon reciver, AVRX2100W, but now I'm stuck.
    At first, the AC/DC converter (MAG258MG) had blown, so I replace that along with some diode's, see attached picture.
    When measuring the output voltage I get 1V, and it should be 5.2V.
    Any ideas on what could be the cause on the voltage drop? Thanks!
  2. Bluejets
    Bluejets
    4,772
    999
    Oct 5, 2014
    Denon are REALLY complex pieces of equipment.
  3. Martaine2005
    Martaine2005
    3,415
    928
    May 12, 2015
    @Ferdi57 said to check the zener diodes.
    He built a zener diode controller to speed up smps repairs.
    (Google translate).
    Martin
  4. KilgoreCemetery
    KilgoreCemetery
    240
    12
    Apr 12, 2017
    I'm no expert when it comes to this sort of stuff (read noob), but from what I understand, the optocoupler is supposed to regulate the amount of voltage that the SMPS puts out. If it's reading wrong it could throttle the output. Something like a bad zener mentioned above could certainly cause it
