help with triacs
Discussion in 'General Electronics Discussion' started by zhanna, Nov 6, 2014.
  1. zhanna
    zhanna
    Nov 6, 2014
    i have a thermostat that i need to replace in as the heat stays on for my snake and i really dont want to to cook the part i have curruntly in the thermostat is bta08-600tw is it possible to replace it with a bt137-600 triac many thanks in advance :d
  2. (*steve*)
    25,497
    2,839
    The former device requires a max of 5mA to operate, the latter 35mA. It may not work if the circuit does not provide sufficient gate drive. Try looking for a sensitive gate triac.
    And please don't cook your snake.
    edit: typically it requires 5mA in the most common quadrant (the one specified for the original device) so it may work, and it probably worth a try.
