Z
zebeste
Background: I'm a wildlife biologist with a background in computer programming. I also had some basic EE experience and digital logic experience when I first started in college, but what skills I had have degraded significantly over the last 8-9 years. Basically, I'm not helpless when reading simple schematics and datasheets; I can usually figure out from a high level what a circuit is supposed to do, and given enough time, can trace through individual components and pins to figure out how everything works from from a low level standpoint. Where I fail is actually designing the details of a circuit from the ground up, especially figuring out the placement of resistors, capacitors, etc, and their respective values.
The project: I do small mammal trapping involving large grids of traps. I want to attach to our traps a circuit that activates when the trap door closes and keeps track of how long it has been closed. When we arrive at the trap, we can record the time from a 7-segment display along with the current time, which allows us to determine the time at which the trap closed. This information potentially has several uses for me.
Parameters: I'd like to have it be able to run for 24 hours using rechargeable batteries. Ideally the clock would be set to increment the counter every minute, but a 5 minute interval would be acceptable if the cost savings is significant enough. I'm aiming for a $10 budget, which seems reasonable given the prices I've been able to find on digikey for things like clocks and timers. Ideally though, $5 would be awesome. The reason being that I'm aiming to make at least 10 of these things, hopefully 50-100.
What I have so far:
It's very crude and high level, but I think it'll work. Basically, to be able to count minutes for 24hrs should require a 12-bit counter, and a 4 digit display. If I go with 5 minutes, an 8-bit counter and 3 digit display will work. But as I mentioned above, the 5 minute option is only if the cost savings is significant, which I don't think it will be.
Basically, to cut down cost, I was thinking of separating the display driver and 7-segment display into a separate module because I only really need one or two. Depends on how expensive the connector will be. But it also has the added benefit that the driver and display will only draw power when we need to read it. When I first started looking for ideas, I came across the 4-digit counter and display driver with multiplexers, but at around $10 a pop, I feel like my way might be cheaper.
At the beginning of the circuit is my attempt at a latch that once activated will keep the circuit running until the power is turned off. This design choice has to do with the nature of field trapping not being a controlled environment and minimizing potential problematic situations.
So, does the overall design seem feasible? or does someone have a better (cost effective) solution? If it's good, I would really appreciate help with getting the schematic finalized.
Thanks.
What I have so far:
Thanks.
