Help with Telephone Circuit
Discussion in 'Electronic Basics' started by Trudeau, Feb 14, 2005.
  1. Trudeau
    Trudeau Guest
    I have build the following project.
    http://electronicsworld.tripod.com/telephonesimages/12.gif
    The circuit works for the most part.
    There is one problem however that I have.
    The problem seems to show its self in two different ways.
    1. The light turns on at erratic times, eg when the furnace turns off. Not
    all the time but every once and a while I hear the forced air fan of the
    furnace turn off and click the relay in the smart light turns on and the
    light turns on. I'm sure the furnace is on a separate circuit.
    2. When someone calls in at the end of the first ring when there is darkness
    the light turns on. Fine exactly what I want. However sometimes the light
    keeps clicking on, remaining on for as long at the capacitor allows, clicks
    off and then clicks back on then remains on for as long as the capacitor
    allows etc. several times. Some times its 3 times sometimes up to 10 times.
    It's what I call a bounce. The light turns off, you hear the relay click OFF
    and then it seems to bounces back ON and remains on for its scheduled time.
    The relay is a 5 vdc relay with the right voltage rating to switch 120 Volts
    AC. I have it connected to a outlet in a box that I plug the 40 watt lamp
    into.
    I assume the problem is that some how the a 120VAC surge in power eg the
    furnace and the lamp turning off is tripping the relay. The tell tail sign
    of this is that if I pull the plug from the lamp that is plugged into the
    "triggered" outlet and sort of push the plug in and out a few times I can
    make the relay "CLICK" and it keeps the light on for the scheduled time
    limit. In other words when I make my own "Power Surge" it trips the circuit.
    It seems odd to me because, the 120 volts is suppose to be completely
    separate from the phone circuit. How can the 120 volts AC cause the relay to
    "bounce" as described. And more to the point how do I prevent it?
    I hope Ive made it relatively clear on what my problem is.
    Do you think it is simply the relay, is perhaps a bad choice or even could a
    different Diode than the 1N4007 that is used over the relay be used to solve
    the problem??
    Thank you.
  2. peterken
    peterken Guest
    Looks to me as if a glitch comes in from the phone line itself (the "ring"
    terminal) which triggers the first '123.
    Anything of size say about 2V *will* trigger IC2 and thus IC3 and so on,
    meaning the circuit is built way too sensitive to just detect something like
    a ringtone.
    As far as I see it, I'd increase the level at which IC2 'passes' anything.
    Might do it by connecting 2 zener of say 27V in series with R1, making sure
    the zeners are "anti-series" (cathodes connected together).
    Motivation : Since a 'ringtone' is at least about 60Vac it will pass, but
    anything smaller will be blocked by the zeners.
    Another way would be to "slow down" any glitches at the output of IC2.
    Motivation : Since a "ring" always lasts for at least say 0.5 sec, removing
    any glitches shorter as say 0.2 sec might do the trick there, so no more
    false triggering occurs.
  3. John Fields
    John Fields Guest
    The first thing I'd do would be to put about 1000µF across the 5V
    supply where it comes into your box (I'm assuming you're using a
    wall-wart of some sort) and the second thing I'd do would be to put a
    0.1µF ceramic directly across the Vcc and ground pins of the chip.
    One other thing you might consider is replacing the chip with HC,
    since the HC versions usually come with Schmitt trigger inputs (check
    the manufacturer's data sheets) and your day/night detector has _no_
    snap to it at all. Also, the HC will provide you with substantially
    more base current for the relay driver than the 123 can. Lastly,
    since the 123's low output voltage will never go above 0.4V, I'd get
    rid of the 2.2k resistor on the base of the relay driver.
  4. Trudeau
    Trudeau Guest
    The power supply is a 9 Volt AC/DC adaptor and then I use a 7805 to bring it
    down to 5 Volts (although when I put my meter on it it appears to be more
    like 4.8 VDC)
    I think ( and I have the whole thing in a junction box right now
    functioning) if I recall the caps I used with this are 10uf ??
    Eg
    (12-9v) [7805]
    +Vin --------1 2 3--------Vout (5v)
    +10uF | +10uF
    Are you suggesting that I change these Capacitors ??
  5. I wouldn't recommend that. I've been advised in the past to use a
    smaller cap on the output side. The reason being that when power is
    removed, the output cap can hold the output pin voltage above the input
    pin voltage since the input cap will discharge faster. I haven't
    sacrificially killed any 7805's yet to prove that out, but it seems
    reasonable.
    I've seen quite a few schematics showing a diode connected from the
    output pin to the input pin. It remains reverse biased as long as power
    is applied. When power is removed, the diode only allows the output pin
    to rise a maximum of .6V(or whatever Vf is for the diode) above the
    input pin. This should allow any size capacitance to be used on the
    output side.
    I would also recommend adding a .1uF cap to ground on the output pin to
    help prevent oscillation.
  6. peterken
    peterken Guest
    your use of the diac is about identical as the two zeners,
    only difference is the diac voltage decreases to about zero if triggered
    while the zener-voltage remains at its level
    Increasing R1 to 100k makes the internal led of IC2 "glow" less for lower
    voltages,
    might also reduce small glitches however is less reliable
  7. peterken
    peterken Guest
    Whenever *any* circuit gets powered there are *always* transient effects,
    even in integrated circuits
    Increasing/decreasing capacitances will not cure those effects, increasing
    power supply caps might even get things worse since longer transients exist
    Designing circuits so that transient effects cannot harm anything does the
    trick
    Just look at C2/C8 timing caps, and imagine a transient on the power
    supply...
    Avoiding "power-on-light-on" might be done for example by slowing down the
    base of T1
    One other thing : I'd reduce R8 to say 560...680 Ohm, since a TTL out
    *never* reaches 0V at "low"
    (usually somewhere between 0.4 and 0.8V, bringing Vbe of T1 at say 0.5V
    worst case thus *possibly* conducting T1 somewhat unwillingly if IC3out is
    "low")
  8. Trudeau
    Trudeau Guest
    Thanks for your advice. In trying to understand this a little bit, so that I
    can apply this to other circuits I make.
    Why do you think a slight spike or oversight (if those two words are
    synonyms in this case) would cause the relay to trigger. An increase in
    voltage "shouldn't" cause the relay to trigger. If the voltage dropped I
    could see this. Eg. when I plug in the DC adaptor it understandably turns
    the light on for its period of time because its charging the circuit, if I
    can put it that way. Perhaps I'm confused, I assume that when the Furnace
    for example turns off the voltage surges for a moment. Maybe it does drop.
    As if its turned off then on. I suppose lights sometimes flash when motors
    are turned on indicating that there is a drop. But as well shouldn't the AC
    adaptor which is 9 volts hold some Inductance keeping the circuit from
    dropping. Unfortunately I don't have a scope to test this, and would not
    know how to use one if I did.
    Sorry for writing like a stream of consciousness .
    Appreciate your help in understanding this phenomenon. For future projects.
  9. Trudeau
    Trudeau Guest
    Thanks for your Ideas.
    I should say, (I didnt before for brevity and I didnt think it was the
    issue) I increased the R1 to 100K and I added a diac to the ring line
    inseries.
    The reason I did this was because when ever someone picked up a phone the
    light came on. The diac and 100K solved this problem. The break over voltage
    interestingly enough I think was 27-32 Volts. About what you wanted. Your
    use of the two diodes together are an interesting way of doing this. I think
    (I'm strickly amature so I may be wrong) but the diac does the same or
    similar as the two diodes together head to head. I have sometimes wondered
    why in some circuits people had diodes anti-series I see now. Your using the
    break down voltage in your favor. IF IM RIGHT.
    Regards
  10. Trudeau
    Trudeau Guest
    Thank you for your responses and advice.
    For full disclosure (I didn't put all the details in my original post for
    brevity)
    1. I put a diac in the ring line with a break over voltage of about 27-32. I
    did this because when people picked up the phone the light came on . I also
    put a 100k Resistor at R1. This seemed to solve the problem of the light
    coming on because of phone line issues. eg people picking up phone or
    turning phone on in the case of wireless handsets. I didn't mention these
    changes because I didn't think they were the problem. or that the phone line
    was the issue.
    I think based on what you have said you would agree.
    2. I actually did change the LS123 to a 74HC123. I did this because an
    electrical engineer acquaintance was nice enough to look at the schematic
    before I made it and made the suggestion. He said something about it being
    more resilient to voltage issues. It appears you two are singing from the
    same song page.
    I don't know if this will change your advice;
    Back to your first bit of advice
    I am using a 9 Volt AC/DC adaptor ( Wall Wart as you call it)
    I then am using the following
    (12-9v) [7805]
    +10uF | +10uF
    One poster has already suggested that I
    "i would put like a 200 min on the input side and
    a 500 min on the output side."
    I think (and verbal descriptions are always hard to understand) Your
    suggesting the same kind of thing.
    Using a 1000uf on the in line from the + to the -.
    I'm not sure if the mis leading info I gave you regarding the HC / LC would
    change your advice on the 0.1uF from Vcc to ground on the chip.
    Regards
  11. Trudeau
    Trudeau Guest
    PS. I did ground Pins 6 and 14 as per datasheet for HC123.
  12. Jamie
    Jamie Guest
    i don't see what your 5 Volt supply is, but its common to have
    electronics perform resets and do funny things when powering up.
    its called oversight. :)
    any ways, you could try using a large capacitor on the 5+ line to
    help hold the charge for those short minor pulses in the line.
  13. Jamie
    Jamie Guest
    yup!
    10 is very small, try something in the
    line of 200 uf and up.
  14. John Fields
    John Fields Guest
    The reason the light was coming on before was because of the pulse
    created by going off-hook. When the phone is on-hook, the phone line
    sits at about 45VDC and then when you go off-hook that voltage drops
    down to about 6V, so you were coupling that ~ 40V level change through
    C1 into the opto's LED, causing it to flash momentarily, but long
    enough to trigger the first one-shot. What you've done with the diac
    and the resistor change is to limit the amplitude of the pulse into
    the opto to the point where it no longer generates enough light out of
    the LED to turn on the transistor and fire the one-shot.
    However, the phone line could still be part of the problem if what's
    happening is that the fan cutting off is generating a magnetic pulse
    which is being radiated by the power wiring, picked up by the phone
    wiring and being coupled into your first one-shot. Not likely, but it
    _could_ happen, depending on how close the phone line is to the fan
    wiring... The easiest way to find out if that's the problem would be
    to disconnect the phone line and exercise the fan a bunch of times to
    see if the problem goes away.
    No change; with the HC123 in there there's even less need for R8 since
    Q will, essentially, go to the ground rail when it goes low.
    Yes, but thinking about it a little bit more makes me think that this
    would be a better way of doing it:
    WALL-WART +9-12V>----+-----[82R]------------->RELAY +5
    +----[78L05]---+-------->LOGIC +5
    [1000µF] | [0.1]
    WALL-WART GND>-------+-------+------+-------->LOGIC GND
    +----------------------->RELAY GND
    While there's nothing wrong with the 7805 you're presently using, the
    78L05 can easily supply all the current the logic needs out of a nice
    little TO-92 package and, this way, the relay's operating current is
    taken from the dirty side of the regulator and any transients or junk
    it creates will be sucked up by the 1000µF cap and also blocked by the
    regulator. Also, a separate ground line for the relay connected right
    at the cap to keep the relay's ground current out of the rest of the
    circuit couldn't hurt
    The 82 ohm (1/4 watt) resistor is based on your having a 5V relay with
    a 100 ohm coil drawing 50mA from a 9V source, the resistor wasting the
    other 4 volts from the [9V] wall-wart. _But_ since you say "9-12V" I
    suspect that what you have is a 9V wall-wart, but that it's being so
    lightly loaded that its putting out 12V. If that's the case, then the
    resistor would have to be 150 ohms, 1/2 watt in order to drop the
    other three volts.
    No, that 0.1µF is always a good idea since it heads troubles off at
    the pass...
  15. Trudeau
    Trudeau Guest
    Thanks again for your advice.
    Actually, and again because I'm learning the the >(12-9v) may have been
    miss leading. I copied it from the little diagram that I had in how to use
    the 7805 and it meant to me anyway that I could start with anything from 9
    to 12 volts. and the regulator would bring it down to 5 volts. I know that
    you could actually start with a higher input voltage but for us home bodies
    who has a 30v AC/DC adaptor. Most everything is 12 or under. (my experience
    anyway) I have not or don't recall anyway actually checking the voltage on
    the AC/DC adaptor accept what its rated for which is 9Volts.
    Again thank you for the advice I must now think it through. I have not seen
    a 78L05 but looked it up and sure enough there it is. It does look like a
    better regulator. Or at least more suitable for this application. I can't
    imagine anything I would do that would actually need 5v, 1 amp that can come
    from the 7805.
    Thanks again I will digest it all.
  16. w_tom
    w_tom Guest
    Some of the usual suspects not seen in responses. Do you
    have a bypass capacitor adjacent to the 74HC123? Bypass cap
    is more critical with the HC version compared to the LS
    version. And it must make a short connection to that 74HC123
    chip. Schematic does not show it.
    You did connect power and ground to pins 16 and 8. HC chips
    can be powered, unstable, via other pins if the Vcc and Gnd
    pins are not connected.
    Another has recommended the relay be grounded separate from
    HC ground. Remember, wire is an electronic component and not
    a perfect conductor.
    Many responses assume the phone line is electrically
    isolated from the rest of that circuit. Maybe. But then
    separation between phone line components and wires is
    important for proper operation.
    You are suffering a transient problem. But too many post as
    if a transient enters on one wire, causes the problem, and
    terminates. View transient problems in terms of both incoming
    and outgoing path. For example, the transient may enter on
    one AC power wire and leave on the other. Or it may enter on
    one AC wire and leave via a not so well separated wire to
    phone line.
    Remember, there is no complete isolation between relay wiper
    and relay solenoid. We have seen where a transient on the HC
    output will actually trigger that IC to change state.
    An oscilloscope using two probes (in differential mode)
    would go a long way to finding the problem in but minutes.
    Currently we all can only speculate. Provides above are some
    examples of the usual suspects.
  17. Trudeau
    Trudeau Guest
    Thanks for you tips. I keep adding data to my knowledge.
    The idea of grounding the relay etc is an interesting one suggested by you
    and another poster. Im a little unclear on this exactly. I would not have
    thought that on such a little circuit it would be much resistance. If I
    understand what people are saying I asume what people really mean there
    should be a separate negative - connection put closer to the emitter side of
    the T1 close to it to prevent the electricity traveling as far to the relay.
    And absorb some of the voltage fluctionations. If you put it on the
    collector side it would trip the relay. And not work properly. If people
    mean someone else I would apreaciate knowing.
    Another respectable answer was to "separately" power the + side of the relay
    of a sort.
    see "John Fields February 14, 2005 1:42 PM" in this thread for details. I
    would have never thought of that and find it a facinating way of doing it.
    Its a lively news group with some thoughtfull answers.
    Regards
  18. w_tom
    w_tom Guest
    In electronics, noise on the ground pin will cause more
    noise problems as compared to noise on the Vcc line or other
    IC pins. Therefore we may create separate digital ground,
    analog ground, and periperhal driver ground that only join at
    one point. This longer distance in copper between the
    different family of components creates reactive electronic
    components - the copper traces - to separate the different
    grounds.
    In your case, digital electronic ground and the relay
    peripheral ground would be separate until both meet where a
    power supply ground connects. Copper traces are more
    electronic components. Resistance is not the problem. Copper
    impedance is the reason we do these things. This electronic
    nature of copper is also why the bypass capacitor (typically
    ceramic) must be located adjacent to the 74HC123.
  19. ryan wiehle
    ryan wiehle Guest
    looked at your schematic. I suggest you replace the opto-coupler
    with a schmitt-triger type opto-coupler to avoid
    multiply spikes during the ring-cycle.
  20. peterken
    peterken Guest
    Since ringtone is about 60Vac there'a always multiple triggering during the
    rincycle...
    Replacing the opto with a schmitt trigger type would only be helpfull if a
    slow changing dc voltage would be applied at the 'ring' line
