adrian polley
- Feb 2, 2016
- 8
- Joined
- Feb 2, 2016
- Messages
- 8
hi all. hoping to get a bit of advice/help.
im a tradie trying to fix a submersible site pump that stopped working last week. ( i usually fix about 60% of my own tools if its the simple problems)
it was pumping quite clean water. moved it from one spot to another to pump out, then smoke suddenly came from the top of it and the main switch at the house meter box tripped.(which suggests a short)
so i packed it up and now its weekend i decided to see if i can see whats up.
so ive pulled it apart and inside looked good as new. there is no smoke or overheat smell at all. the leads all test out so cant see any obvious place for a short or the source of the smoke.
and being a completely sealed unit, for smoke to be visible on the outside there must have been a lot more inside it. but there is no sign of it.
one part that is beyond my limited knowledge is the motor start capacitor.
generally when a capacitor fails it will swell but this one hasnt. like everything else inside it looks new.
i dont know how to test/investigate problems of a start capacitor and dont even know how they work. ive tried watching a few you tube vids but the ones i can find are very bad at explaining things.
any ideas advice would be appreciated.
