[email protected]
I have the following scenario. I have to do an automated blinds
installation. The control circuit for the blinds consists of the
following: A microcontroller which switches on two relays for up and
down, a single motor does the up and down. Two limit switches input to
the micro to prevent the rail from moving too far. The actual control
consist of 3 buttons. Which supplies three 12vdc signals back to the
microcontroller. Up, Down and Stop.
The problem I am having is that I need to integrate this into my
homeautomation device. It is a dynalite relay module. From which I
normally use two relays. One for up and one for down. Usually the
blinds I use only has neutral, a live for up and a live for down. So
the cabling have been done already. I've only got 3 wires running to
the blinds and I need to make this control circuit run with this.
Any suggestions for a circuit?
I've been thinking of using a relay which is wired common to 12V
normally closed to stop and normally open to up and then another relay
(or a double pole) with the common to 12V, normally closed to stop and
normally open to down.
The only problem I can see is that the stop signal will be sent to the
micro the whole time.
Otherwise I am going to have to reprogram the micro. It is an MDT and
I don't carry any knowledge that type.
Thank you
Johan
Thank you
Johan
