TBennettcc
- Dec 4, 2010
- 292
- Joined
- Dec 4, 2010
- Messages
- 292
I received an old adjustable DC power supply. (The plate on the top reads: D.C. Test P.S. / MOD PS-1 / 0-50 VDC 4 AMPS / 115 VAC PRI 60 HZ)
I didn't feel it was working correctly, so I tore it apart and made a schematic. I need some help in deciphering what exactly this was designed to do, and how it is supposed to work. (I have no idea if this wiring is factory, or if the wiring is "correct"; I have a feeling someone has messed with this before, as some of the wires and switch contacts are in need of replacement. I don't know if any circuits have been modified from what they might have been.)
According to the attached schematic, I'm good with most of the beginning:
AC 120V in, power indicator lamp (LMP1), then the fuse (F1) (I'll switch those two around when I rebuild this... not much sense having an indicator light for line voltage even if the fuse is blown...) The next part (VAR1) is a Type 10B Powerstat Variable Transformer (AKA, Variac), rated 2.25 amps, 297 VA. (I didn't have the right schematic part in EAGLE CAD, so I made do with a center-tapped transformer. You get the idea.) Next is a two-to-one transformer (TR1). Next we have the bridge rectifier (BR1).
This is the part where things get fuzzy. The rest of the schematic is a bunch of resistors connected to switches. I talked to a friend, and he said that the resistors connected to SW2 between poles 0 and 1 are to limit current. Okay, fine, but how does that work if my AC (and thus my DC) is finely adjustable? I could see that maybe with a single input voltage, but how does this work over the range?
Also, R3 is simply a piece of wire loosely coiled up (3 turns, .75" in diameter by 1.5" in length when coiled). I can't imagine what purpose this could have served? When I opened up the unit, there was a char mark on the metal plate directly above this wire. It's possible I could have caused this by plugging the unit in and turning knobs without knowing what those two rotary switches were connected to at the time.
Resistors R4-R7 are 10ohm, 10%, 2 watt wirewound resistors. With both contact points not connected at the rotary switch, I measured the resistance across R4, and get a value of 718 ohms??? Even if Ohm's Law is followed, those resistors are in parallel, which means the resistance should go down (to 2.5 ohms, if my math is correct), not up, and certainly not to 718 ohms!
The plate on the unit states a maximum ampacity of 4 amps, but I was easily able to exceed that number using an ammeter connected across the final VDC + and - terminals and just turning the Variac up. Granted, that piece of wire (R3) almost caught fire, so I quickly turned it down.
The rotary switches also seem to play a role in adjusting the meters on the front. Both meters appear to be the same. The scale on both meters goes from 0-100. There are no other markings on either meter, aside from a stamp on the back of each molded into the plastic from the Simpson Electric Company. The needles move on the meters, but not accurately. Any ideas for these?
This would be an awesome troubleshooting tool for me if I can get it to work. How do I make this work, and safe (i.e., no risk of electrical fires)?
I apologize for the book. I wanted to be clear. Any and all help is greatly appreciated.
Thank you for your time.
