Why do you need to "drop the amperage"?
Is it because you have a device that requires 16V at 2.08A? (I assume your power supply is 16V).
If so, then you need to know that the current is determined by the load, not the power supply. If it only needs 2.08A and that voltage, then that's what it will draw.
