Help with repairing a gate
Discussion in 'Sensors and Actuators' started by RolfeEP, Oct 6, 2018.
  1. RolfeEP
    RolfeEP
    9
    Nov 22, 2011
    This morning, the remote for my gate did not want to open the gate.
    I tried using another gate opener, but this other remote did not open the gate either.
    I tried opening up the motor to see if there was anything I could adjust, but I'm not sure where to begin or what to look for.
    Does it need new batteries? Do dead spiders mess up the circuitry? Is moisture from the weather to blame?
    There must be something wrong with the motor. How should I handle this?
  2. Nanren888
    Nanren888
    51
    7
    Nov 8, 2015
    The circuit board hanging out the front is a little suspicious.
    Remember, anything may have dangerous voltage on it at any stage.
    Is it not powered, or maybe powered, but stuck?
    When you stand by the gate and use the remote, do you hear anything? That is, does it try to move?
    That is, check that power is available?
    Is there a fuse or breaker for this? If so, you could check it. If the breaker is out, then the unit may have a fault that caused the breaker/fuse to shut it off.
    There seem to be power sockets on the device. If the sockets are standard for your area, you could see if they are live, by seeing if something normal will run from them?
    If no power, look backwards, why there is not power. Breaker/fuse.
    If power and not moving, you are looking for why it is not getting to the motor.
    If power and trying to move, you are looking for why it can't move.
  3. RolfeEP
    RolfeEP
    9
    Nov 22, 2011
    I should have mentioned earlier, you can see what looks like a light switch.
    When I press the button on the gate opener, especially when I stand next to the motor, I can hear a click.
    If I flip that light switch, and try hitting the gate opener again, no click.
    That must mean the power is working fine.
    I also neglected to mention, that maybe it might need lubrication.
    You open this gate manually by pushing down that pedal. It unlocks the gate and you can move it freely.
    I should probably cut the duct tape and try it. It has to at least be able to move manually.
  4. RolfeEP
    RolfeEP
    9
    Nov 22, 2011
    Okay, well it opens manually.
    A little heavy, but it moves.
  5. Bluejets
    Bluejets
    3,104
    608
    Oct 5, 2014
    OMG........:eek:
    You don't seriously expect this thing to keep working do you?
    I can spot at least a dozen fault areas......get an electrician ......and a box to sit over the top (at least)
    RolfeEP likes this.
  6. Nisar-von-Voltenbräackter
    36
    3
    May 23, 2018
    The presence of a lowly click sounds like a switch problem.
    RolfeEP likes this.
  7. Nanren888
    Nanren888
    51
    7
    Nov 8, 2015
    If the problem is not purely mechanical, as you suggest, seized, lubricant &c.
    Then,..
    If your unit is as in the image, exposed to the weather, the motor seems as if it gets a hard time.
    Also, motors often need other adjacent components to start up, such as capacitors, which are prone to fail with time. Depending on the motor type, what the motor needs and what these compoents do varies somewhat.
    It might be time to call that electrician, or gate service guy, who knows about this model.
  8. RolfeEP
    RolfeEP
    9
    Nov 22, 2011
    No the motor is not always exposed to the elements. It has a cover. I just removed it for the purposes of this topic.
    I've been opening my gate manually and have gotten used to it.
    I did not know that capacitors will fail with time, so I wouldn't know how to handle them. With that said, the right thing to do is to stop and just call an electrician as you suggested.
  9. Tha fios agaibh
    Tha fios agaibh
    1,840
    582
    Aug 11, 2014
    Try pushing in that red thermal reset button on top of the motor, and yes call an electrician to at least fix the conduit with exposed conductors. (missing box connector fitting)
  10. shrtrnd
    shrtrnd
    3,651
    448
    Jan 15, 2010
    This may just be me, but the first thing I'd do is put a load on the battery, and check the voltage.
    Everything you described (motor won't open the gate, but the relays 'click'), would indicate a low battery.
    Something may be broken, but I'd do the battery check before I tore into the circuitry.
    Good luck.
  11. Tha fios agaibh
    Tha fios agaibh
    1,840
    582
    Aug 11, 2014
    Motor is powered by building branch circuit (I assume 120v) through the conduit on the bottom. I doubt there even is a battery.
    Likely the gate jammed and tripped the motor overload (red button on top) or, there's a fuse for the motor that poped.
