help with relay or something else
Discussion in 'General Electronics Discussion' started by turbogt16v, Mar 27, 2015.
  1. turbogt16v
    turbogt16v
    173
    4
    Mar 27, 2015
    helo,i need help on figuring out circuit for solar panel,battery,and load,charger regulator.
    we have in pic
    [​IMG]
    solar panel,battery and load.
    The blue thing are relays,the connection is drawn because i dont know if one can do job or i need 2.
    so,i want solar to charge battery and load,when battery is full relay disconnects all connection .
    the battery circuit is running when solar is getting less power than needed for load by relay to .
    is this possible,if is then how,
    thanks
  2. Tha fios agaibh
    Tha fios agaibh
    2,083
    694
    Aug 11, 2014
    I would not use relays, but install a diode inline with the solar panel. That would allow the battery to charge from solar during daylight, but also stop discharging current in the opposite direction.
    Arouse1973 likes this.
  3. Tha fios agaibh
    Tha fios agaibh
    2,083
    694
    Aug 11, 2014
    If you are dealing with high wattage solar panel, or a pv array the regulator and relay might be the way to go.
    From first glance, looks like you have a small panel charging a small radio.
  4. turbogt16v
    turbogt16v
    173
    4
    Mar 27, 2015
    I know about the diode ,did not draw for simplicity of pic.
    I think i need to use relays and or LM311 or LM2596
    yes small portable radio
  5. Tha fios agaibh
    Tha fios agaibh
    2,083
    694
    Aug 11, 2014
    How much current does the solar put out?
    What kind of battery?
  6. turbogt16v
    turbogt16v
    173
    4
    Mar 27, 2015
    solar about 16-18v about 1A,recargable batery bank 15v
  7. Tha fios agaibh
    Tha fios agaibh
    2,083
    694
    Aug 11, 2014
