Hello all, I have a 3D printer with an S-200-12 power supply. Last Saturday I was printing and a pop came from the power supply. I opened it and saw something had blown. It is labeled RT. I can't find a schematic anywhere so I was wondering if someone knew what it is and where I can get another. I was in another room when I heard the motor making a noise like it was stuck then I heard a pop. When I got to the printer the extruder carriage was all the way to the right and jammed the motor. The printer is a Prusa Mendel I got on Ebay and there is no limit switch to disconnect the motor on the far right. That is supposed to be limited by the software I guess. I am going to add a limit switch so this never happens again. There is also no limit switch on the y axis upper limit so I will be adding one there as well.
Attached are 2 pictures of the blown part. Or whats left anyway. The text behind the lead says AC/L
Thank for any help you can give.
