Help with Philips 42" plasma TV
Discussion in 'General Electronics Discussion' started by alan5, Dec 20, 2010.
  1. alan5
    alan5
    Dec 20, 2010
    I've got a 42" plasma model number 42PF5520D/10 but i've got no picture or sound what could it be?
  2. alan5
    alan5
    Dec 20, 2010
    Doe's anyone know why i can't get a picture or sound on my philips 42" plasma model number 42PF5520D/10 tHANKS
  3. janagyjr
    janagyjr
    67
    Dec 17, 2010
    As I understand it, if you lay a plasma tv down flat, you will ruin it. Try googling the problem your having (and provide some more details). My information is sketchy and second-hand at best, so don't take my word for it.
  4. jerryg50
    jerryg50
    57
    Apr 18, 2010
    No picture and sound together, usually points to a defective power supply, or there is a failure on one of the other boards and the power supply is in the protect mode.
    These sets are normally serviced by doing board swaps, as just like servicing a computer. In some instances the new board may require some calibration. For this you would have to consult the service manual. You will also require the proper test and calibration equipment to make the adjustments.
    If the set is more than about two years old, replacement boards may no longer be available. Call the manufacture tech support for proper and accurate information.
    Jerry G.
  5. gurmej
    gurmej
    4
    Jan 1, 2011
    Hi
    There is achance that a flexi ribbon cable has become loose or disconnected
    remove the rear panel and check all cables and connectors this was a common fault with these models at one time
    post a picture with the rear panel removed i might have the answer
  6. davenn
    davenn Moderator
    13,793
    1,938
    dunno where you heard that from, have never struck that problem with servicing them :D
  7. janagyjr
    janagyjr
    67
    Dec 17, 2010
    From the fine folks at Wal*Mart who won't take one back if the tv has problems during transport from the store if it breaks and is in this position.
    Trying to find an authoritative source on the issue, though.
    http://www.plasmatvbuyingguide.com/plasmatv/plasmatv-misconceptions.html
    #9 is as close as I can get:
    (emphasis mine)
  8. davenn
    davenn Moderator
    13,793
    1,938
    well any glass sheet will break if dropped even that on a LCD panel ;)
    so its not a plasma screen thing ... and its the jarring or dropping that is the problem
    for normal good use and care taken in servicing laying it flat isnt a problem :)
  9. janagyjr
    janagyjr
    67
    Dec 17, 2010
    Good to know. The only reason I asked that though was because I took someone's word for it (their reasoning was the gas leaks out, good to know that's an utter myth).
