B
Boboranntrottier
I'm working on a Onkyo A-SV610 Pro receiver with no outputs . I've tracked
it down to not getting a low signal from the UDP6345 that controls the
output relays.
I can short out an output and enable the main or remote speakers so I know
I'm on the right track. It gets clocks and inputs when I hit the mail
speaker switch.
The odd thing is that the remote speaker button don't seem to be working
either by generating input to the 6345 or by lighting the remote label on
the display.Before I assume its the 6345 or rip apart the front panel I
thought I'd see if anyone has seen this before and can explain why the
remote speaker switch wouldn't be working
Also any suggestions on where to get the UDP6345 would be appreciated
in Advance
BOB
output relays.
speaker switch.
in Advance
BOB
