D B said:
I am trying to build a small business security system that will let
me use key cards for employees to enter and exit the building
without setting off the alarm. I don't need to track employees per
se. Just have the cards allow entry and exit and interact with the
main security system. We are installing a new entry door that
will allow an electronic actuator to unlock the door. I am trying
to locate control panels that allow for both a keypad and a key
card system. Any help or suggestions are greatly appreciated.
Hi Denis,
There are several systems on the market which can do what you want.
Honeywell makes a Vista-128 series control panel which can
interconnect with their VistaKey system. The Honeywell system is
intended for larger commercial premises. ELK Products makes a
"residential" home automation system that could be used for combined
security and access control. The ELK-M1G system is UL listed for
residential use but if you're not going to use it for fire alarm and
you're not doing the installation to comply with a requirement of
your insurance company, that doesn't matter. Alternatively, you
could install any of a number of small access control systems. These
aren't "security systems" in the sense of alarms but they can limit
access to those with a card. Either of these approaches can be done
by a DIYer with a modicum of tool skills and a bit of patience.
Another approach would be to install electronically operated door
locks such as the Trilogy series from Alarm Lock Systems. These do
not require a card -- just a code. Each employee has a unique code
which can operate one or all locks. Codes can be added or deleted at
will. The beauty of this approach is it doesn't require special exit
mechanisms. Doors operate manually from the inside. Hit the push
bar or turn the handle to exit.
One consideration which may affect your selection is fire sprinklers.
If you have a fire suppression system and you install magnetically
operated locks, you'll need to tie the access control system into a
UL Listed commercial fire alarm or sprinkler alarm to comply with
building codes. If you use electronic locks which allow instant
egress this isn't an issue.
Regards,
Robert L Bass
Bass Home Electronics
941-925-8650
4883 Fallcrest Circle
Sarasota · Florida · 34233
http://www.bassburglaralarms.com
