Help with motor comparison
Discussion in 'Sensors and Actuators' started by JerryP, Feb 9, 2012.
  1. JerryP
    JerryP
    3
    Feb 9, 2012
    Hello,
    I'm not to savy when it come to electronics.
    I purchased a Dept. 56 piece. It has a 12 volt 60Hz 3 Watt motor to operate the skaters.
    I found a similar motor 12v 60Hz 4 watt motor. Would this motor replace the original?
    Also in the piece is 4 LEDs and a 6 volt bulb all connected together.
    Any help would be appreciated.
    Jerry:(
  2. BobK
    7,662
    1,676
    You would also want to know the torque and RPMs of the motors to find a replacement, voltage and wattage is not enough. If the new motor spins twice as fast, you might have some hyper skaters!
  3. JerryP
    JerryP
    3
    Feb 9, 2012
    Bob,
    Both motors say nothing about the torque. RPM's are the same 10/12.
    I'm wondering about the wattage 3 on the original and 4 on the replacement, because of the LED's. I don't want to burn them up. The way this piece is built, if I burn the LED's out. I'll throw the piece away. No replacing the LED's.
    Jerry
  4. BobK
    7,662
    1,676
    If the RPMs are the same and the wattage close, I think the motor will likely work.
    I do not understand your concern about the LEDs. They should not be affected by the motor. Also, why no replacing the LEDs?
  5. JerryP
    JerryP
    3
    Feb 9, 2012
    Bob,
    I got a hold of an old buddy of mine. He said it shouldn't matter between the motors. Ones a little stronger than the other.
    The LED's are sealed - To get to them, I would have to destroy the lamp post.
    Thanks for your knowledge,
    Jerry
Similar Threads
Loading...
