Hello there!
Background:
So, i have this Sidewinder 92626, which has been my trusty companion for some 14 years, it was a gift from my childhood, and it worked like a wonder.
One day i noticed some bad contact, windows stopped recognizing the device, got the cable replaced, all good. A year later the same problem reappeared, but this time i already knew how to use a soldering iron, replaced the cable myself, worked for a while, same problem again, replaced the cable, and it insisted on not getting recognized by windows, until it stopped being detected altogether.
So i acted, took an USB-B port from an old device, made the proper connections to the pcb, and used an siemens foxconn high speed printer cable that was lying around, having a removable cable should be much better, i thought, since it can be replaced without soldering, plus its a more reliable cable.
-Something that the original cable had, close to the usb plug, was a ferrite core, which this cable doesn't, i intend to install one, im not entirely sure if the absence of this could cause severe malfunctions or failure to connect (the previous cable that i used had a ferrite bead and didn't work anyway, but its an old and long cable, with a new usb-a plug i soldered to replace the original, oxidized one, anyway i doubted about its reliability, thus the replacement)
But no joy, windows doesn't even detect that something was plugged. The board does receive the 5v
Maybe i'm missing something? I once took months troubleshooting an amplifier that had a bad 6.3mm jack
Could it be something repairable? should i accept its death? could be a dead chip? Messed the USB wiring(im no expert at it)? Does something seem bad in the pictures? I don't consider my soldering job on this piece optimal, i lack resources since im not home, so i couldn't clean it up before reworking the connection. Could it be the culprit?
A quick inspection with the multimeter on the jumpers reveals current going through, so i believe the connection does work.
I assumed DM to be D- and DP to be D+ on the usb pinout
The chip is a COB, i couldn't find any schematics, so if it is dead then i think its the end of this board.
I noticed a little spot of what seems to be solder on one of the paths near the chip, i don't know if that was there before
Here i stand, with a dead stick and terrible itch to "fly" . Replacing it with something equivalent in terms of quality, is expensive, and i would prefer to invest that money on the execution of my project to build my own joystick.
Maybe im just in denial and should give up?
Any tips and suggestions will be greatly appreciated!
Many thanks in advance!
Background:
