Circuit1.jpg is the alarm portion of the circuit. The top circuit is a turn off after delay that will turn off the signal to the alarm portion (goes through nor gate with reed switch to tell if door is open). The bottom right part is a turn on after delay which will turn the alarm on after a certain time delay. The thyristor portion in the middle has been giving me trouble. Initially I couldn't get it to work at all, but now it sort of works. The signal in the side of the thyristor sets it so even when the door is closed or opened again, the alarm will still count down/go off. The second portion of the circuit (circuit2.jpg) is a decade counter configured as a combination lock. Whenever the code is entered correctly then it should pulse then invert to a 0 so that it will turn the thyristor off, resetting the alarm etc. Unfortunately, my efforts to do so with mosfets and transistors have failed so far. Is there a way to do this, or am I going to have to use a relay (don't want to!) Many thanks, Reuben!
Categories
Platforms
Content
