I'm sorry but this is a really bad assignment (my opinion). I'm totally struggling with it, trying to figure out what the teacher wants (lol).
I agree with you, based on what was provided... but I was not in class, so it's hard to tell.
Some details for you that may greatly help:
Flowing Electricity will create a Magnetic Field around the wire. The 'Right Hand Rule' will give you more detail about the direction of this field in relation to the direction of the Electrical current.
This is a two way relationship though... which means that a Magnetic Field can actually 'create' Electrical Current as well!
There is a catch though. The Magnetic Field itself isn't exactly what creates the current... it's the 'change' in the Magnetic Field that does.
There are two ways to change the Strength of the magnetic Field:
- Physically move toward or away from the Field. (Used in Generators)
- Change the Electrical Current that is causing the field. (Used in Transformers)
Is the paper provided, there is no current flow because the switch is open. As soon as you close the switch, current will flow which will create a new magnetic field around the wire in the circuit. If the loop on the right is close enough, the change of magnetic field in the wire of the circuit will cause a briefly cause current to flow in the loop. When you open the switch, the magnetic field around the wire of the circuit changes again... which will cause current to flow in the opposite direction in the loop if it's close enough.
Additionally, you can leave the switch closed, and move the loop toward and away from the circuit which will cause brief Electrical alternating current in the loop.
Hopefully this helps you out. If you want to try a simple experiment to show off the electrical creation of Magnetism, you can make an electro-magnet with a nail, some wire and a battery
Tightly and neatly wrap the wire around the length of the nail, and apply voltage to the wire. The magnetic field around the wire will create a temporary magnet with the nail that you can use to pick up small items like paper-clips and loose change. You can also repel or attract other magnets based on the polarity of the battery! Does it push a magnet away, reverse the battery and try again.
