Hi Everone!
I have a question on finding a replacement for this capacitor. I believe this to be an aluminum electrolytic capacitor and was used in the early 1970's for an automotive low fuel relay. When the fuel sending resistance dropped below 30 Ohms, this relay would oscillate a dash board light bulb with a red lens printed as LOW FUEL. No problem rewinding the burned coils, but I am having difficulty with all of the numbers show on the capacitor to be able to find this replacement. The physical size is approximately 1" wide x 1/2" high x 3/8" deep. This circuit board fits into the metal mounting frame, so size is an issue.
I believe I understand the markings as:
.5 - ?
+- 20% Tolerance
85C - Temperature Rating
200 V - 200 Volts
900 - ?
Any help identifying the two ratings that I show with a ? and a correct replacement would be greatly appreciated! The impedance on one of these working capacitors is -100 Ohms.
Here are some pictures...
Thank you,
Jim
.5 - ?
+- 20% Tolerance
200 V - 200 Volts
900 - ?
Thank you,
Jim
