help with homework
Discussion in 'Electronics Homework Help' started by markben, Dec 27, 2016.
  1. markben
    markben
    4
    Dec 27, 2016
    hi
    i need to find the current in the circuit number 48 it should be 0.6 amps.
    can someone explain me how to solve it.
    thanks.
  2. Laplace
    Laplace
    1,252
    184
    Apr 4, 2010
    If you color-code the wires it should be easy to see that R1,R2,R3 are in parallel; R6,R7,R8 are in parallel; R4,R5 are in parallel.
    Harald Kapp likes this.
  3. markben
    markben
    4
    Dec 27, 2016
    thanks
  4. markben
    markben
    4
    Dec 27, 2016
    hi
    i need your help. i need to find the total resistance in the circuit the answer is 0.5 ohm.each resistor is 1 ohm. but i don't understand how they connected. can you teach me how to recognize the type of connection if they connected in series or parallel connection.
    thanks.
  5. Laplace
    Laplace
    1,252
    184
    Apr 4, 2010
    Again, if you color-code the wires then it will be easy to see which resistors are shorted out.
  6. markben
    markben
    4
    Dec 27, 2016
    i really get stuck.
    this is what i got.
    after redrawing the circuit.
  7. Laplace
    Laplace
    1,252
    184
    Apr 4, 2010
    If you color-coded the wires, you would not need to work so hard.
    Arouse1973 likes this.
