Categories
Platforms
Content
The bel, and the decibel, are measures of ratios, not necessarily power ratios. dB can be used to express current ratios and voltage ratios; the formula is dB = 20 log10 (VOUT / VIN).The decibel is a measure of power ratios, so you will need to know the input and output impedances.
I have the current values
Gain in volts = 3.89
Gain in Decibels = 11.809
dBV is dB relative to a reference level of 1V RMS. It's used when you're specifying an absolute signal level. When you're specifying a gain or attenuation, i.e. the ratio between two voltages, you just use dB.Yes I agree with Kris. If you only have voltages and nothing else then express this in dBV, using the formula as above #5.
When I was studying electronics almost 50years ago, I was censured by my tutor for not realizing that the result of the formula dB = 20 log10 (VOUT / VIN) could only be correct if the two voltages were measured across a common impedance. This is also implied in the second para of the section ‘Field Quantities’ in the Wiki link below.The bel, and the decibel, are measures of ratios, not necessarily power ratios. dB can be used to express current ratios and voltage ratios; the formula is dB = 20 log10 (VOUT / VIN).
