Since it is the same circuit, yes the same rules apply.
The limitation on the maximum size of the sense resistor will be due to the input impedance of the op amp, noise, and leakage in the mosfet.
The minimum value of the sense resistor is dependant on the current and power ratings of the mosfet, the ability to turn the mosfet on hard enough, circuit resistance, offer voltage of the op amp, etc etc.
What current do you require?
One important factor is the magnitude of the negative voltage presented to the op amp. This subtracts from the voltage available to overcome Vgs(th). You may want to keep it under 1V, but you need to study the datasheet for the mosfet (whatever you choose)
