Help with capacitor question.
Discussion in 'General Electronics Discussion' started by hvacdocgary, Oct 14, 2020.
  1. hvacdocgary
    hvacdocgary
    May 19, 2020
    I just retired for Heating and Cooling and finally have some time to fix things around the house. I have some fluorescent lights that have bad capacitors and am having trouble finding a site on line that has these. I appreciate any help on finding these. Can't see it on pic but it is 200 volt.In heating and cooling we could go up in voltage but not down. Does the same hold true in electronics?
  2. Bluejets
    Bluejets
    4,216
    894
    Oct 5, 2014
    Yes...but your pic does not show voltage.
  3. HellasTechn
    HellasTechn
    1,537
    213
    Apr 14, 2013
    Generally speaking, yes it does, if you have enough space on the pcb and housing.
    You will probably find them at your local electronics shop and on ebay or such sites.
  4. ratstar
    ratstar
    138
    Aug 20, 2018
    Its true. If you up the volts on the capacitor, it makes no difference to the workings of *ANY* circuit if the battery or power-source stays the same.
  5. hvacdocgary
    hvacdocgary
    May 19, 2020
    Perfect ! Thanks for the help!
