Help with basic design
Discussion in 'Electronic Basics' started by Robin Cull, Feb 3, 2004.
  1. Robin Cull
    Robin Cull Guest
    Hi all,
    I'm pretty new to this electronics game having come from a software
    background. I am trying to design a basic interface board between the
    Analog Devices ADXL202E accelerometer and the LabJack U12 USB DAQ.
    I have a basic design sketched out on paper but I would like some help
    with some of the details.
    Firstly, the ADXL202E is an 8-pin LCC surface mount component
    (5mm*5mm). I have soldered surface mount before but it's a pain and
    as I only have two parts (and they're expensive to replace) I don't
    want to solder them directly unless I have to. Also using SMD makes
    the use of other through-hole components more difficult (two-layer
    board). I have been searching, so far in vain, for a socket type
    adaptor that will clamp onto the LCC package and have through-hole
    pins. I've seen these things for larger (more pins) parts but not one
    this small. Any tips?
    Second problem is capacitor choice. The ADXL202E analogue output is
    filtered by a capacitor. I've figured out that I need to use 0.47uF
    filtering capacitors (this will yield a bandwidth of 12.5Hz so I can
    sample on the DAQ at 25Hz). I am guessing that as these are being
    used for timing purposes they need to be fairly precise so normal
    electrolytics of +/-20% won't do. What kind of capacitors should I be
    using for this purpose?
    Thirdly, working on the assumption that I may not be able to get an
    adaptor for the LCC package I've created a part in Eagle so I can make
    a schematic. I'm having a little trouble with the layout. Initially
    I created a symbol as a rectangle with 8 pin-outs on the right hand
    side but doing it this way makes it really hard to layout the
    schematic without making a real birds nest out of it. Any
    recommendations on how I should tackle this?
    Finally, and this question is more specific to the ADXL202E and the
    Labjack, I plan to use the +5V and common 0V lines from the Labjack to
    power the board, the part maxes out at 5.25V and I've placed a 100Ohm
    resistor in series with Vdd to smooth the power. I assume this is ok,
    looks fine from the data sheet. The signals for the analogue sampling
    are coming in series after the filter capacitors. I think I've got to
    go to ground after this but I am not sure how. Also the datasheet for
    the ADXL202E mentions that it maybe necessary to op-amp buffer these
    signals to get sufficient power out of them to read, I am not sure
    whether I need to do this or not. Could anybody clarify these points
    for me?
    Thanks a bunch for putting up with these questions, I know they are a
    little varied.
    Cheers,
    Robin
