Help with alternator to battery bank wiring
Discussion in 'Power Electronics' started by callumsmith52, Aug 4, 2016.
  1. callumsmith52
    callumsmith52
    4
    Aug 4, 2016
    I am trying to wire up a Mitsubishi Alternator to my 12 volt battery bank. I have the battery positive connected to the B+ post and a cable going from the battery negative earthed on the alternator. The alternator is internally regulated and has 2 more terminals labelled S and L. Im led to believe that the S terminal is the voltage sensing terminal for the regulator and the L is for the lamp. I wired from the S straight onto the B+ post. With the L terminal i wired to a lamp then to a switch and then back to the B+ post. From what ive read when the switch is on the light should come on and once the motor starts up the light should fade out. This is not happening to my set up. Does anyone have any ideas why. Am I missing a vital wiring connection somewhere or have i got it completely wrong.
  2. Kiwi
    Kiwi
    375
    93
    Jan 28, 2013
    Sounds like you have it wired correctly.
    What size lamp have you got on the "L" terminal? Should be about 2-4watt.
    What is the history of the alternator?
  3. callumsmith52
    callumsmith52
    4
    Aug 4, 2016
    The lamp is a 2.5 watt LED.
    Alternator is second hand out of a working car.
  4. callumsmith52
    callumsmith52
    4
    Aug 4, 2016
    This is it With the B+ in the foreground with
    all the wires. The earth is from the battery
    and is in the background
    The small brown wire is S and goes
    straight to the B+. The other small wire is
    L and goes to the lamp then the switch
    then to B+. The biggest wire going to B+ is
    the positive from the battery. Alternator
    definitely sounds like its putting the motor
    to work
    [​IMG]
  5. callumsmith52
    callumsmith52
    4
    Aug 4, 2016
    Sorry for the child like paint skills but here is the wiring diagram
  6. Alec_t
    Alec_t
    2,980
    804
    Jul 7, 2015
    That may be the problem. Try a filament lamp.
  7. Kiwi
    Kiwi
    375
    93
    Jan 28, 2013
    Try it with a normal bulb.
    LED's usually don't pass enough current to excite the alternator.
