No, the simple way would be with a resistor, but that would probably get very hot.
Alternatives would be to use PWM and vary the duty cycle from low (maybe 30%) to high (99%) or perhaps doing the same thing with an inductor in series with the bulb to produce a crude SMPS.
Yea that resistor is not going to happen. May be some in-rush limiter, thermistor, but I am not going to worry about it until I prototype this. There are 1000's of these on police cars and aircraft... but it is something to think about. A capacitor across the bulb or resistor + capacitor (RC) will smooth out the pulse. The bigger the capacitor the "smoother" the square wave. The issue is weight and complexity. I have made PWM dimmers with 555 timers, work like a charm! However I am trying to KISS. This is just a simple astable multivibrator with transistor switching. I don't want to re-invent the wheel... If the bulb life is reduced so be it.
A simple approach I've seen is using a power transistor with limited base current. This acts to limit the available current to the lamp causing it to turn on more slowly. This has the additional benefit of limiting the cold current without a lot of components. It does reduce the voltage to the lamp slightly, but not a lot (0.2V perhaps)
I will have to play with that, but I do want FULL voltage/current for max brightness! I will have to research the affect cycling has on halogen. If there is no data I will test it my self. The life of a MR16 is in 1000's of hours at steady. I'm not that worried about the halogen bulb. I am already running them at higher volts, so I have halved the life. Aircraft do not put on hours like cars or lamps in homes. 500 hours is several years of use. I have a commercial whelen SSF-2150 flasher. It's a pure DC pulse, on and off, about 100 times/min or about 1.7 Hz. There are 1000's of these commercial wigwags flashing halogen car headlights..
If these are the same lamps that are used for the headlights, then you need to ensure that the circuit operates correctly whether they are turned on or off. Are they? and if so, what is the desired behaviour?
This is actually an experimental aircraft. The two lights out in the wing tip, normal use is for landing and taxi at night. In the air, day time they will be used for "recognition lights" to be more visible, reducing mid air collision risk. Strobes are required for night, but useless in daytime, due to low lumen's. Strobes don't need much light at night to be visible. Landing lights make more light, (albeit focused in a narrow beam), by a factor of at least 10 or more, much more. Thus the "recognition lights" more visible in day time. Flashing landing/taxi lights in the wing tips makes RELATIVE motion back and forth, so people can see you easier form head-on or some converging frontal angle, during the day. The rule of the air is SEE and BE SEEN. So one must look out the windscreen, but also being visible is a plus.
1.5Hz is (with 50% duty cycle) 0.3333 seconds on, 0.3333 seconds off. The entire cycle takes 0.66667 seconds. If the bulb filament stays red hot for at least this time, then you should be fine with no additional steps.
That was a typo. Each cycle is 0.6667 or time = 1/f, where f = 1.5 Hz ... Saying 1.5 Hz at 50% duty implies divide by two. Yes off period is half of period or 0.333 sec. With out test data, I can only guess if that's enough to keep the filament hot (not cooling between cycles). It's more pulsed than On/Off. Not able to eyeball it directly there is still a glow between on periods, using the commercial Whelen flasher on the oscilloscope. There is no big overshoot in current Again the Whelen is on & off and there's some glow between on period. It is too bright to eyeball direct, but in a dark room the bulb is still HOT (making light). I have done some home work my friend. It would be nice to keep some current going through it, I agree, but I'm not going to belabor this aspect. The benefit to complexity does not seem warranted. Halogen is be more forgiving and run hotter then hell, so keeping them warm is not an issue.
I rejected using HID lights for this reason, you can't flash them or it's more difficult. The flashing circuit for a HID is more critical. HID lights must also be warmed up before flashing. HID is expensive, so reducing their life is not cost wise. A MR16 bulb is a buck or two. Bright white LED technology is catching up and making the scene in aviation, but it's not up to making as much lumen's as the halogen in this small form factor and cost. Flashing LED's would be nice, but I have enough electrical power to do the job.
Turning 2 mosfets on is a good idea, but using a P and an N channel is probably not going to work unless you can switch the +ve lead to one lamp, an d the -ve to the other.
If you can only switch the +be lead, then you will need to use P channel mosfets for both, and this will require that you employ an inverter to switch the other P channel mosfet. You specify using a 2222 as an inverter which sounds right, but the rest of the explanation is odd.
No that's not what I am doing. I'm using only MOSFET P-channels, two for wigwag and two more for steady switching, allowing use of a low current rated switch. The 2N2222 is the inverting transistor for one light, as I said. Not sure what is "odd"? Could you be more specific.
Since you demanded it (?) this is the circuit. Thanks.
