Jeanguypataterubberboot
- Jul 9, 2013
- 41
- Joined
- Jul 9, 2013
- Messages
- 41
Hi there, I have a Yamaha RX-V640 that I have had for years and most of it's life has been in storage. When I turn it on it comes on for 1 second then turns off. I downloaded the service manual and got it to turn on in diagnose mode. I get the message "PS PRT 18% F". I connected it to a Variac and when I dial it down to less than 115 volts as opposed to the full 120 volts it powers on normally. This leads me to believe that it is a power supply problem. Here is the confusing part. When I measure the output of the Power Supply at 120 volts in diagnose mode the readings are about 3 volts low from the schematic. Nothing that I saw looks burned. I have very limited electronics knowledge so I am learning a lot here but I would love to fix it. I have an oscilloscope but don't have an isolation transformer so I don't dare use it as I heard that could create smoke in the scope.
Thanks in advance for the help.
Pierre
Pierre
