Timbeckett
- May 10, 2014
- 7
- Joined
- May 10, 2014
- Messages
- 7
Ok essentially I do a bit of electronic work in my spare time, currently I operate a dcc oo gauge train layout at home which I run my electric dc steam engines on. Okay so put simply I want to use what's called a seuthe smoke unit or even build my own from scratch. The problem is that the smoke unit is essentially just a wire filament that heats up oil to produce smoke, but the unit draws too many amps to be used by the decoders output in one of my engines. So I need a relay in order to switch on a larger circuit drawing more amps.
Here are the numbers to work with
The decoder puts out roughly 15v dc current and has a max rating of 100ma draw on it. Usually these wires are used for lights etc. these wires will be used to switch the relay on and off.
The smoke unit will be powered directly from the track instead of directly connected to the decoder and draws 400 ma when connected. It also has a positive and negative wire.
So my question is this,
I don't know which relay switch I need to connect this up? Also the relay needs to be relatively small to fit in a locomotive.
When the relay is powered it will be constantly on or constantly off I need one that doesn't work by pulses of current it needs to be as I said when powered it makes the circuit, and when not powered it breaks the circuit.
So which relay do i need to do this, also I live in the uk so if you could give me a link to website so I can purchase it that would be extremely helpful
