Help with a (simple - I think) circuit design
Discussion in 'Electronic Basics' started by Zinfari, Jul 31, 2004.
  1. Zinfari
    Zinfari Guest
    I think this circuit should be fairly simple, but I have no idea how
    to find the correct chip for this application. Here is what I'm
    trying to do:
    Basically I have a variable resistor (10k pot). When the resistance
    is < 2.5k I want an output1 to be set to GND and output2 open. If the
    resistance is >7.5k then I want Output 1 open and Output 2 set to GND.
    At all other times I want Output 1 and 2 to be open (so from 2.5k to
    7.5k).
    Is there a chip or a couple of chips and some resistors that I can put
    together that will accomplish this? I have access to 3.3v and 5v.
    Thanks for any help,
    -Zinfari
  2. Depends on the accuracy you need - simpliest solution would be to use
    two comparators, connect the pot betwwen GND and +5, and three
    resistors in series also between GND and +5. Connect the comparator
    inputs between the pot and the resistors.
    _________________
    +5______|___ |
    | | | |comparator
    | | res |
    pot-| res
    | | res |
    | | | |comparator
    GND-----|---- |
  3. John Fields
    John Fields Guest
    Yeah, but you left out all the good stuff:
    +5 +5 +5 +5
    | [2K49] | [1K2]
    | | | >---+---->OUT2
    [10K]<----------+--|-/
    | | | +V
    | [4K99] | |
    | | | [1K2]
    | | | >---+---->OUT1
    | [2K99] |
    GND GND GND
    An LM393 would be OK for the comparator at 5V except for its common
    mode voltage of V+ -1.5V at the high end, so either something with
    rail-to-rail inputs should be chosen, or a series resistor added to
    the pot and the divider string. Something like this should do it, but
    you might want to check the numbers just to be sure:
    +5 +5 +5 +5
    [10K0] [10K0] | |
    | [2K49] | [1K2]
    | | | >---+---->OUT2
    | | | +V
    | [4K99] | |
    | | | [1K2]
    | | | >---+---->OUT1
    | [2K49] |
    GND GND GND
    BTW, the resistors are all 1%'ers except for the pullups and,
    probably, the pot.
  4. Visi Mail
    Visi Mail Guest
    Thanks folks I think this is close to what I"m looking for, but I don't
    think it will work for my situation. If I understand the circuit drawn then
    either the output is grounded OR it has 5v on it? I don't think I can have
    any voltage on the output. I either need it grounded or effectively an open
    circuit.
    Let me try this again (and maybe that answer is the same and I just need to
    dig into the circuit more).
    What I basically am trying to do is create a switch and ideally I'd like to
    isolate the the output from the rest of the circuit. I think the voltage
    comparitor is going to work but I think I need a bit more. Here's the way
    I'm visualizing this.
    If the resistance is <2.5k then O1 is tied to GND and O2 is tied to I2
    (which wouldn't have anything connected to it so it's an open circuit). If
    the resistance is >7.5k then O1 is tied to I1 and O2 is tied to GND. If we
    are between 2.5k and 7.5k then I1 is tied to O1 and I2 is tied to O2 (i.e.
    both are open).
    +5 I1 I2
    | | |---->OUT1
    [10K]<--| |
    | | |---->OUT2
    GND GND
    If it helps make the circuit simpler I could also make it work a little
    different. If the resistance is <2.5k then I1 is tied to O1 and O2 is open.
    (so basically an isolated switch is closed if the input requirement is met
    otherwise it's open) If res is >7.5k then I2 is tied to O2 and O1 is open.
    If 2.5k-7.5k then O1 and O2 are open.
    +5 I1 I2
    [10K]<--| / / |-----GND
    GND O1 O2
    Thanks for the responses,
    -Zinfari
  5. Randy Day
    Randy Day Guest
    How about running O1 and O2 thru some
    open-collector gates (i.e. 7405)?
    That gives you open or ground, but
    you'll have to watch the current
    limits...
    or simply build your own:
    R | O1*
    ___ |/
    O1 -|___|--|
    GND
    R | O2*
    ___ |/
    O2 -|___|--|
    GND
    created by Andy´s ASCII-Circuit v1.24.140803 Beta www.tech-chat.de
  6. John Fields
    John Fields Guest
    Aaarrghhhh!!!
    Mea culpa. I'm so used to pulling up open collectors that I didn't
    even think about it...
    Just get rid of the pullups and it'll do what you want.
    +5 +5 +5
    [10K0] [12K4] |
    | | | >---->OUT2
    | [4k99] |
    | | | >---->OUT1
    | [2K49] |
    GND GND GND
    There is another issue which hasn't been dealt with yet, and that's
    whether or not you can stand chatter on the outputs at the switching
    points. If you can't, then that needs to be addressed
  7. Zinfari
    Zinfari Guest
    Thanks for the reply. I don't think chatter will be an issue. It's very
    unlikely for the resistance to remain at the switching point. I think that
    should do it, but just out of curiosity I just came across this just before
    I saw your post. http://pdfserv.maxim-ic.com/en/ds/MAX4620-MAX4640.pdf
    (Basically a 74HC4066). I think this would work as well or am I missing
    something here?
    Thanks again for all the input,
    -Zinfari
  8. Rich Grise
    Rich Grise Guest
    Yes, and it would be bipolar, thus much more like a simple switch closure.
    An NPN open-collector only acts like a switch one way, so I think you're
    closer to the original spec.
    Has the OP looked up "window comparator"?
    Cheers!
    Rich
  9. John Fields
    John Fields Guest
  10. Note that comparators are usually open collector, meaning they are
    'open' if they are high. Thats why JF's diagram had a 1.2k resistor to
    the power supply 5V rail. If you get rid of that, I think the circuit
    works as is.
    Regards,
    Bob Monsen
  11. Zinfari
    Zinfari Guest
    Thanks for all the help everyone. It was much appreciated. After reading
    up on open collectors the circuit makes sense and should work great!
    -Zinfari
  12. Sorry, I simply overlooked the OP's spec of the pot (10K). Sloppy
    reading :(
