HELP with a simple circuit to fade in a LED
Discussion in 'LEDs and Optoelectronics' started by lefam, Dec 2, 2010.
  1. lefam
    lefam
    43
    Nov 18, 2010
    Hi guys!
    I am pretty new to electronics. I have just designed a circuit that turns on a LED when you press a tactile switch and fades out the LED when you open the switch.
    Can you help me designing a circuit that fades in a LED when a switch is closed? Please something simple (in preference a RC circuit).
    Thank you
  2. (*steve*)
    25,490
    2,832
    Please show us the circuit you have designed (as a schematic).
    I am presuming you have a capacitor that is charged and then discharges through a resistor and a LED.
    Putting the capacitor, the resistor, and the LED in series will do pretty much what you ask, but you also need to provide a way to discharge the capacitor. But I am makinf assumprions about your original circuit that may not be correct.
  3. lefam
    lefam
    43
    Nov 18, 2010
    Please forget the circuit that fades out the LED.
    I want to build from scratch a circuit that fades in a LED. The circuit should not have anything to do with the fade out circuit.
    The circuit should contain a tactile switch (push to make switch). When the switch is pushed it should fade in the LED. I think the capacitor would be discharged when the switch is opened.
    I have attached the LED fade out circuit schematics. Can you recommend me a nice program that draws schematics?
