Fusionwerks
- Oct 25, 2017
- 3
- Joined
- Oct 25, 2017
- Messages
- 3
OK, so i posted this question on another forum, and i got some responses, and i'm sure they will work, but i cant seem to find anyone willing to just draw me a simple schematic to show me in plain English how to accomplish it. Below is a simple drawing of the current setup.
The "Controller" shares a common ground (-) with multiple different voltage power supplies for devices (in this case it is 12 VDC) There is also a 5 VDC, and 24 VDC in my setup (Not shown).
The Devices are wired to the corresponding voltage power supply (+)
The "DEVICE" is a 12 VDC beacon light that has 2 modes: (A) Strobe, (B) Rotate sequence
It has a momentary switch (S2) that shorts to ground, and the beacon changes the modes.
The device defaults back to mode A whenever the circuit is broken and then re-established.
What i would like to do is somehow create a simple 555 circuit to make this change to mode B every time the controller sends the signal on S1.
It would have to send a simulated button press (short to ground) and release immediately after S1 "closes" on the controller. S1 is not technically a switch, but an output on a controller board, it just seemed like the best way to draw it.
I have read a little about 555 circuits but i dont know how to do this using the ground as a signal (trigger) or if its even possible.
