help with a servo motor
Discussion in 'Datasheets, Manuals and Component Identification' started by ziphlox, May 20, 2013.
  1. ziphlox
    ziphlox
    15
    May 20, 2013
    hi,
    i wanna ask if there is any datasheet for this sort of servo motor (its picture is attached to this post) in which there are 5 wires.
    i only know that two of them are + & -, but the other three are the ones i can't figure out what are they used for or how are they connected in a circuit.
    i'm hoping i could find some help in here since this is my first post in this forum.
    thank you guys.
  2. gorgon
    gorgon
    603
    24
    Jun 6, 2011
    How do you know this is a stepper motor?
    Have you got any type number or any additional information at all?
  3. ziphlox
    ziphlox
    15
    May 20, 2013
    this is not a stepper motor, it's written in the simulation software "proteus ISIS" that it's a servo motor.
    the two wires on the sides are for the connection of the motor + & -, the other 3 are the ones i can't figure out where they are exactly connected or what are they called.
    here is a picture attached so that you would be sure it is not a stepper motor.
  4. ziphlox
    ziphlox
    15
    May 20, 2013
    i forgot to mention that when you point out on those 3 other wires with the cursor, it appears that each one has a name, there is P2, PC in the middle & P1.
    i just don't know how can i connect them to make the servo motor work in a speed control locked loop (or i guess that's how it's called).
  5. gorgon
    gorgon
    603
    24
    Jun 6, 2011
    Ok, sorry mixed with another post. For a servo motor I would think that the 3 extra wires are a tacho output or positional decoder output. I would think that one wire is common, and the other two are quadrature pulsed outputs. More unlikely, if the servo is a single turn output they could be part of a potensiometer, for position.
  6. ziphlox
    ziphlox
    15
    May 20, 2013
    thank you for the help, i appreciate it.
    i hope i can find some more precise answer.
  7. gorgon
    gorgon
    603
    24
    Jun 6, 2011
    I would think that PC is common, and P1 and P2 are quadrature outputs, pulsing a number of cycles for one rotation. Normally there will be 90deg difference between the outputs, and you can then decode direction and rotation of the servo motor.
    Take a look here for more: http://www.ni.com/white-paper/4763/en
