Clearly, your intentions were never in doubt. Either was
the doctor who bled a patient to death to cure the fever. To
cure a patient, at minimum, understand basic electrical
principles such as the many types of transient.
Meanwhile, even a MOV manufacturer does not claim to absorb
energy of a surge. For same reason that a wire gets warm, so
does the MOV. It shunts .. and to earth ground.
Meanwhile, electronics already contain effective internal
protection as even demanded by industry standards of 30 years
ago. Items such as the Corcom or equivalent are already
inside appliances; even due to FCC requirements. Even that
capacitor is often inside the appliance - but with higher
voltage ratings for human safety reasons. IOW any protection
that might work on a power cord is already inside the
appliance. Plug-in protectors hope you never learn that; so
they publish brochures chock full of half truths.
Once Apple installed MOVs inside their products. Why does
Apple no longer install those $0.10 parts? Because MOVs
inside the computer or on a power cord are not effective.
Again (and to appreciate why, one must understand some first
year EE concepts), the effective MOV earths a typically
destructive transient. That means it must be located short
(less than 10 feet) to a single point earth ground.
Does a refrigerator generate transients seen by MOV? If so,
then the MOV will degrade to ineffective in but weeks or
months. A graph provided in MOV datasheets makes this
obvious. MOVs are installed for transients that occur
typically once every eight years. Any trivial transients such
as noise from the refrigerator - the appliance must already
have protection to make such transients irrelevant.
If a refrigerator generates such destructive transients,
then what protects your dimmer switches, GFCIs, smoke
detectors, and furnace controls? We don't visit the hardware
store weekly to replace these because, well, first learn the
numbers. Those transients are made irrelevant by protection
already inside appliances. Those hyping ineffective plug-in
protectors again hope you don't learn this.
You may wish to take a short break. Already posted are
significant technical facts that require grasp of basic EE
principles.
What does an MOV do when located on the appliance power
cord? It shunts a transient from one wire to all others.
Shunts - not stop, block, filter, or absorb. It does what Ben
Franklin demonstrated in 1752. The typically destructive
transient seeks earth ground. A transient on the black (hot)
wire has been shunted to white (neutral) and green (safety
ground) wire. IOW the transient now has three paths to find a
path to earth ground, destructively, via the appliance. Where
is the protection? As posted earlier, an adjacent protector
can even contribute to damage of the adjacent appliance.
No wonder plug-in protectors are so undersized (MOVs of too
few joules). But again - how many joules on that protector
you think is being protected? What are the numbers? Did that
brochure note why joules must be sufficient?
Again, I am only repeating what is provided in that 'days
worth of reading':
http://makeashorterlink.com/?X61C23DCA
Protectors adjacent to the appliance can even contribute to
damage of that adjacent appliance. Why? First, no short
connection to earth ground. What do destructive transients
seek when destroying transistors? Earth ground. What is the
most important component in a surge protection system? Single
point earth ground.
But again, what do all those industry professionals discuss
obnoxiously in that 'days worth of reading'? Earth ground.
What do you want? Something obnoxiously repeating what plug-in
manufacturer propaganda ignores? Or a sugar coated and
grossly overpriced solution sold in Staple, Circuit City,
Sears, and Kmart?
No earth ground means no effective protection. The MOV is
only as effective as its earth ground. What do ineffective
plug-in protector hope you never learn about? Earthing.
To truly help the OP, first read that 'days worth of
reading'. Appreciate how widespread the plug-in protector
propaganda is. Effective MOVs are installed, in greater
numbers, within well earthed 'whole house' protectors. The
protector being only as effective as the quality of and
connection to that earth ground. By tens of times, the
cheapest and most effective spike protection is properly
Meanwhile, I believe the OP wanted to detect surges - not
eliminate them. The tranzorb solution or something equivalent
would be a better solution. Since he has not asked, I have
not provided additional information.
