Help with a low resistance meter
mevrocket
Jun 7, 2012
Jun 7, 2012
Hi all
new to the forum and not the best with electronic.. altho im not to bad at soldering and deciphering diagrams.. i just have no idea with the techie side of things.
id like some help if possible from one of the Electronic wizards here..
id like to make a simple circuit that will light up an led when the resistance in the circuit falls below a 100 ohms. or a circuit that i can adjust the resistance that triggers the LED
the circuit will be powered by a 12 volt car battery
thanks
Paul
Harald Kapp
13,722
13,722
You want a continuity tester with a treshold of 100 Ohm.
Look here: http://www.extremecircuits.net/2010/04/continuity-tester-circuit-diagram.html
This circuit probably works from 12 V, too.
I don't think the type of OpAmp is very critical. If you want to / have to use another OpAmp, just make sure it operates from a 12 V (9V) single supply. The threshold for continuity/discontinuity detection should be adjustable by the potentiometer.
Harald
