Help With a LED Clock Kit Please
TheDutyPaid
May 4, 2017
6
May 4, 2017
6
Hello all,
I put together this quite simple LED clock kit I got from ebay. When I powered it up it all works apart from 'D' segment being permanently lit.
I'm no stranger to hand soldering but circuits do confuse me a bit.
Any help would be great
hexreader
Apr 21, 2011
135
Apr 21, 2011
135
Welcome to the forum :)
It looks to me as if there is a defect in the PCB provided.
Maybe Google for others who have had the same problem with your board. I reckon there must be a lot of other dissatisfied customers out there.
Pin 15 of the Atmel 89C2051 chip should connect to segment D of the display, but does not.
See how pins 11 to 19 all have a PCB trace to the resistor pack except pin 15...
If you are feeling brave, solder a tiny wire link pin 15 of the 89C2051 to the resistor pack pin just above.
(or return the unit as faulty if you prefer not to take any risks)
Hope I got it right - follow my advice at your own risk - I will not resolve any issues if I turn out to be wrong. Maybe wait to see if others reply either agreeing or disagreeing before making any changes.
Good luck..
AnalogKid
Jun 10, 2015
2,893
Jun 10, 2015
2,893
Please post something: the schematic, a link to the assembly manual, whatever.
ak
AnalogKid
Jun 10, 2015
2,893
Jun 10, 2015
2,893
The display pinouts in posts 4 and 5 are not the same.
ak
TheDutyPaid
May 4, 2017
6
May 4, 2017
6
Thank you hexreader, perfect advice.
Just added a blob of solder between the two pins and the clock is working perfect. Not sure how to set the different functions, but I am sure to work that out.
73's de Edd
Aug 21, 2015
3,622
Aug 21, 2015
3,622
No sign of that intereconnecting foil link path having EVER been there.
Not being so chancy, I would have gone for an intermediate current limiting resistor initially.
The piezo needs its cover peeled off.
73's de Edd
TheDutyPaid
May 4, 2017
6
May 4, 2017
6
73's de Edd
It goes to a resistor, and keeping the sticker on is a old way of limiting the volume.
It all works, I'm happy.
