Help with a circuit question
Discussion in 'Electronics Homework Help' started by MrMoose, Jul 22, 2013.
  1. MrMoose
    MrMoose
    Jul 22, 2013
    Can someone answer this question for me?
    In the circuit shown, the emitter voltage is zero. What is the problem?
    1. R1 is open.
    2. R2 is open.
    3. Capacitor C is shorted.
    4. R4 is open.
    Thanks for any help....studying this stuff has me to the point I am arguing with myself over the answers. :D
  2. (*steve*)
    25,496
    2,837
    OK, consider:
    1) 0V with respect to what?
    2) What components are directly between the emitter and a source of that potential?
  3. hexreader
    hexreader
    126
    38
    Apr 21, 2011
    Since this is your homework, I think you should tell us what you think will happen in each case 1, 2, 3, 4.
    Then we can discuss any flaws in your arguments...
    Simply "answering the question" for you is not what homework help is about.
    Do we assume that nothing is connected to input and output?
  4. Y2KEDDIE
    Y2KEDDIE
    259
    15
    Sep 23, 2012
    Cicuit Diagram
    I'm curious; what does the inverted triangles represent? Is that your symbol for ground/common? Also is Vee positive or negative?
    I would make certain assumptions considering it's a PNP transistor. ;)
  5. davenn
    davenn Moderator
    13,833
    1,950
    that's a pretty common symbol for GND :)
  6. GENESIS_42
    GENESIS_42
    Jul 23, 2013
    You didn't mentioned the value of the resistors & the capacitor,and what kind of mesurement did you used?How can we know that those components are shorted or open?
  7. (*steve*)
    25,496
    2,837
    It's homework. It will essentially work for any positive, finite value.
  8. alfa88
    alfa88
    344
    5
    Dec 1, 2010
    Why not lay it out on a protoboard and end the argument with yourself?
  9. (*steve*)
    25,496
    2,837
    MrMoose has probably already found someone willing to give him the answer already, but in case he hasn't, let's not do his homework for him eh?
    Perhaps (and this is a gentle hint) we can stop posting now unless he returns.
Similar Threads
Loading...
