Help with 5 Pin LCD and Arduino
Discussion in 'Datasheets, Manuals and Component Identification' started by rhydiansmith, Feb 27, 2012.
  1. rhydiansmith
    rhydiansmith
    Feb 25, 2012
    Hi
    I need help with a LCD that I'm trying to connect to my Arduino board.
    The problem is, all of the LCDs that I see on the tutorials and on the internet all have 16 pins.
    My LCD has only 5 pins.
    There are no part or model numbers on it, so I am clueless to what each pin is for.
    I bought it from Maplin.
    Could anyone tell me what each 5 pins are for?
    Or, could anyone even tell me how to connect it to an Arduino board?
  2. GonzoEngineer
    GonzoEngineer
    321
    Dec 2, 2011
    So Maplin sold you the part.....and they didn't provide a datasheet?
  3. Neotron
    Neotron
    17
    Mar 9, 2012
    It's probably a serial LCD display. Maplin should have data on it on their website.
    Just have a look at their website or email them for the pin assignments. They are bound to have it.
    In any case, I have a pile of parralel input LCD displays and went looking for some data on them and found the standard 16 x 2 line display connections are ALL THE SAME (with only tiny variations).
    Also, it is likely that 1 pin is backlight illumination, 1 is ground, 1 supply and 1 the serial input and 1 is the enable. Ground is easy to spot, it goes to everything, supply is often next to it - that leaves only three pins.
