help wiring DPDT relay
jwalker
Sep 5, 2011
Sep 5, 2011
Hi, new here and would be glad of some help please!
I am trying to produce the following circuit, which I have attached.
I bought a DPDT relay which has more pins than I need, but could someone please tell me which pins go where for the circuit? The wiring diagram for the relay is below.
My electronics knowledge is somewhat limited, I am ok with the rest of it but it's just this that has thrown me!
Thank you in advance :)
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
I would suggest the two pins connected directly to "PIN A" and "PIN E" are pins 1 and 16.
The two connections to the normally open contacts could be 4 and 8
davelectronic
Dec 13, 2010
1,087
Dec 13, 2010
1,087
Relay
Hi jwalker.
Use a meters continuity tester to be sure, but i think power 12 volts to 1 and 16 is the relay coil, and your diagram looks like single pole single throw ( SPST ) and you could use pins 4 and 8 or pins 13 and 9 as the switch contacts, not both for your circuit. Use your meter to be sure on the relays pin out, the coil will give a reading in ohms. Dave. :)
jwalker
Sep 5, 2011
Sep 5, 2011
Hi thanks very much for the replies, looking again at the diagram it's making sense!
Will be putting this together tomorrow, thanks again for the help
