T
Trouty
hi there,
A little bit of advice about IC holders please!
I'm modifying a circuit that has a very small 14 pin surface mount Op
Amp that I need to tap into 9to feed off into another circuit). I
reckon my best bet is to "piggy back" an IC socket holder onto the one
that is already on the circuit board (ie solder onto it) as this will
give me a nice stable platform & I can also use pins into the relevant
IC socket legs.
My problem is that this is quite a small op amp. I've measured the
pins...between pins 1-7 (ie one side of the 14 pin) the distance is
only 8mm in total. Does such an IC socket exist? If so where can I
source one from?
Many thanks in antcipation.
Trouty
IC socket legs.
source one from?
Trouty
