HELP! want to power an audio amp with batteries
Discussion in 'Audio' started by jarred2233, Nov 28, 2013.
  1. jarred2233
    jarred2233
    Nov 28, 2013
    I want to know if its possible to power a Muse i25W TA2021 audio amplifier with something like 12Vdc 18AH car battery to drive a pair of Polk Audio db401 speakers. Will the amp only draw the current required or will I have to regulate the power supply? and will the battery last long?
  2. Harald Kapp
    10,350
    2,255
    The power adapter supplied with the Muse is 14V/4A.
    The amplifier may or may not work with 12V. You'll have to test this.
    The amplifier will draw as much current as it needs, you will not need a regulator for the current.
    A 4A fuse in the positive wire from the battery to the amplifier would be a useful safety feature.
    At 4A an 18Ah battery theoretically last max. 4.5hours. In practice the useful liefetime of a fully charged battery will depend on factors like
    - actual current consumption
    - real capacity of the battery (probably less than the nominal 18Ah)
    - temperature
  3. jarred2233
    jarred2233
    Nov 28, 2013
    I BELIEVE THE MUSE M20 WHICH SUPPLIES A BIT LESS POWER DRAWS BETWEEN 12-14 VDC SO I THINK THAT MIGHT BE SAFER THANKS FOR THE HELP
