Help using multiplication with PIC microcontroller
Discussion in 'Electronics Homework Help' started by REDHOTHOBO, Jun 24, 2014.
  1. REDHOTHOBO
    REDHOTHOBO
    Jun 24, 2014
    Hi, I need some help with a task on my electronics course at college. The program underneath should multiply 3 and 2 to make 6 but instead I get 9. Could anyone help correct this please and then turn it into a linear program. Thank you!
    cblock 0x20
    first
    second
    endc
    org 0
    Start:
    bsf STATUS,RP0
    clrf TRISC
    bcf STATUS,RP0
    movlw 0x03
    movwf first
    movlw 0x02
    movwf second
    call addloop
    movwf PORTC
    addloop:
    movwf first
    again:
    addwf first
    decfsz second
    goto again
    return
    end
  2. Ehsan
    Ehsan
    100
    Jun 12, 2014
    cblock 0x20
    first
    second
    endc
    org 0
    Start:
    bsf STATUS,RP0
    clrf TRISC
    bcf STATUS,RP0
    movlw 0x03
    movwf first
    movlw 0x02
    movwf second
    call addloop
    movwf PORTC ;After 'addloop' function returns, you should end the program
    hang_here goto hang_here
    addloop:
    ;movwf first ; At this point WREG is already 0x02 and first=0x03, why do you want to put WREG in first again ?
    movlw 0x00 ; Instead set WREG to zero
    again:
    addwf first ; This is ok
    ;decfsz second ; here you decrement 'second' and put the result in WREG ! that is a mistake
    decfsz second, 1 ;by passing 1 for the second operand the result will be saved in 'second'
    goto again
    return ; OK now you have got the result and the function returns
