Help understanding simple solar charging circuit
Discussion in 'General Electronics Discussion' started by legoman, Oct 14, 2011.
  1. legoman
    legoman
    5
    Oct 14, 2011
    I found this simple 12v solar charging circuit online. http://www.circuitdiagram.org/solar-battery-charger-circuit.html. Can someone please help me understand it. I understand the output adjusting part of the LM317 ic. What I don't understand are the conditions how the transistor is turned on and off. Isn't DC voltage an open circuit to the capacitor hence the transistor will alway be off? What conditions would exist, which would warrant the .5ohm 5watt resistor to be required?
    :confused:
  2. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    I think that a link is missing.
    A connection should be made from the junction of the 100R resistor and the 220nF capacitor to the battery negative.
    When there is more than 0.6V across the 0.5R resistor, the transistor turns on and drops the output voltage so limiting the current to about 1.2A.
  3. legoman
    legoman
    5
    Oct 14, 2011
    OK, thanks. That makes a lot more sense. Could I substitute a 7 watt light bulb in place of the 5 Watt resistor? Would the resistance change in the light bulb with temperature vary too much?
  4. OLIVE2222
    OLIVE2222
    690
    25
    Oct 2, 2011
    The resistance will vary a lot with the temp. don't remember exact values but certainly something like 10:1 ratio.
    Concerning the charging circuit caps are also missing at the LM317 Input. you also drop precious energy in the diode.
    Olivier
  5. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    A 6V 7W bulb will be vey different to a 240V 7W bulb. In use the maximum voltage across the bulb will be 0.7V so a low voltage resistance measurement may be not far out.
    The diode is necessary to stop battery discharge when the light is low. I do not know whether a capacitor is necessary on the input, there is one on the output for stability purposes.
  6. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    Having another look at your circuit, the series resistor is much higher specified than necessary. The power in a resistor is V*V/R, i.e. 0.7*0.7/0.5 this comes down to about 1/4 W. A half watt resistor would be fine and a lot smaller and easier to fit than a bulb.
    duke
  7. Resqueline
    Resqueline
    2,848
    Jul 31, 2009
    I get that a 0.6W resistor is needed even if the transistor turns on at only 0.55V (which it will do at the low collector current). The 1N4001 is not good for 1.2A btw..
    But another question is if the current limiter circuit is neccessary at all. I'd say only if you're using a small battery (3.5Ah) with a large panel (>22W).
    Solar panels are inherently current limited devices, so only if the panel gives a current higher than 1/3rd of the battery Ah rating would an extra limiting be desired.
  8. OLIVE2222
    OLIVE2222
    690
    25
    Oct 2, 2011
  9. legoman
    legoman
    5
    Oct 14, 2011
    A better choice of diode
    Would a Schottky diode 5819 be a better choice?
  10. OLIVE2222
    OLIVE2222
    690
    25
    Oct 2, 2011
    A BYV27 will give you more headroom. or anyone >=2Amp you can source
  11. legoman
    legoman
    5
    Oct 14, 2011
