G
[email protected]
I tried this question in the BASICS forum but did not receive a
response. I thought I would try here next. I appologise in advance
for cross-posting.
Is there a rule of thumb stating how much power an N-Channel MOSFET's
internal body diode (anode at source cathod at drain) can handle vs.
the normal use drain to source power rating of the device?
Does this make sense?
I am using an Nch MOSFET to switch a load to ground in a battery
operated project. The design does not allow me to place a rectifier
diode in series with the load to prevent current flow through the
body
diode in the event of reverse battery connection. I was wondering if
the battery was connected in reverse, would the load limit current
enough to save the device? Unfortunately I never see the power
rating
(or forward voltage drop of this diode) published in manufactures
data
sheets so I have no way to tell.
Thank you in advance,
Ge0
for cross-posting.
body
rating
data
Ge0
