Help to understand opamp compensation
I've found this interesting lecture
www.analogzone.com/acqt0704.pdf
but i don't understand open loop gain with resistor series capacitor
as load.In fig. 6.15 opamp's open loop gain is represented: it is
calculated (i think) at node Vout of fig 6.14, so pole is equal to 1/
(Ro+Riso)*Cl. I don't understand how zero is obtained....
Can you help me?
neon
Oct 21, 2006
1,325
Oct 21, 2006
1,325
Undestand this any amplifier will oscillate at higher frequency if when you cross the 0 Db point at a slope greater then one. What you read is spice simulation . That is not the real world . Spice can make do anything you want .
