Help to find the Schottky substitute?
Discussion in 'Electronic Components' started by [email protected], May 1, 2007.
  1. Guest
    mbr10100ct,Dual Common-Cathode High-Voltage Schottky Rectifier
    www.ortodoxism.ro/datasheets/vishay/mbr1090c.pdf
    I need to replace the above component in a power supply. i check the
    digikey and mouser.com, but they don't have any.
    where can i find a 100V , 10A Dual Common-Cathode High-Voltage
    Schottky Rectifier?
    Can anyone suggest me a equivalent part?
    Thanks!
  2. Ray King
    Ray King Guest
    You might check with IR Corp ( distributors). When I worked there the 80
    volt and above schottkys were sometimes plagued by the guard ring injection
    which made the schottky look more like a fast diode. Those parts are just
    plain hard to make. Is this used in the pfc section in series with three
    others?
    Ray
