Tyler Durdem
- Nov 16, 2014
- 7
- Joined
- Nov 16, 2014
- Messages
- 7
Hey Guys,
I am doing a bath remodel and I am trying to hook the fan up to a switch that will turn it on when hot water flows through the showerhead pipe.
Attached is a diagram of what I have.
I plan to just wrap the thermal switch to the pipe. What I am unsure about is which way is best to hook up the switch to control the fan in a safe manner. I assume low to high voltage relay will be used. I don't want 100V running through the thermal switch at the pipe.
I also want the fan to switch on and off from the wall, but not off if the thermal switch is in activated mode.
It's all basically a fail safe if someone forgets to turn the fan on for a hot shower.
Any advice and parts are appreciated.
