help specing pushbutton switch please?
Discussion in 'Electronic Basics' started by dj, Apr 5, 2004.
  1. dj
    dj Guest
    I'm trying to repair some intercom units in our apt. building and one
    has a broken pushbutton switch that's actuated by a handset
    switch-hook. It has twelve pins in two rows and behaves as follows
    (o---o = switch connection between pins):
    o o---o o o---o
    plunger out --->
    o o---o o o---o
    o o o---o o o
    plunger in <---
    o o o---o o o
    Is this a 4PDT or what? I need to find replacements and the dimensions
    are no problem but I don't know what I'm asking for.
    Many thanks for any help!
  2. Dbowey
    Dbowey Guest
    You are close. Here is 4PDT. It's a good idea to have some separation between
    units, for clarity.
    o o-->o o o-->o
    plunger out --->
    o o-->o o o-->o
    o<--o o o<--o o
    plunger in <---
    o<--o o o<--o o
    Don
  3. dj
    dj Guest
    You know, now that I look at my diagram, I think it has THREE
    positions, like so:
    o o---o o o---o
    plunger out --->
    o o---o o o---o
    o---o o o---o o
    plunger in halfway <---
    o---o o o---o o
    o o o---o o o
    plunger in completely <---
    o o o---o o o
    In fact, yes, that is the way it works, the halfway point is handset
    on-hook, the plunger out is handset off-hook, and plunger in works the
    "open the door" solenoid (it pushes in past the point of on-hook rest).
    And the wipers short two pins, skip two sets, then short another set.
    Any idea what would a switch like this would be called?
  4. CFoley1064
    CFoley1064 Guest
    Subject: Re: help specing pushbutton switch please?
    It would be called a custom switch. Manufacturers of switches will make just
    about anything the customer specifies, especially if the volume is there.
    I think your best shot for a repair would be to
    1) contact the manufacturer for a replacement,
    2) try to repair the switch, or
    3) scrounge a used switch from an identical piece of equipment somewhere. If
    you positively _have_ to get a solution, use a separate power supply, a SPDT
    ON-(OFF)-ON toggle switch, and a couple of 4PDT telecom relays to simulate the
    switch action.
    Good luck
    Chris
  5. dj
    dj Guest
    Yes, when it got into the three-position category it started sounding
    non-standard. The switch action was making no sense to me when I
    thought it had only two positions. Thanks a lot for your help!
  6. Dbowey
    Dbowey Guest
    That is a 4P3T. it is common in rotary switches, but in a push-button switch
    you may need to write to switch manufacturers to find who makes one.
    Don
